I have a 97 sedan with the stock y7 and I recently swapped the transmission to the y8 "B000" trans. After driving it for just a few minutes, 2nd gear has been popping out pretty consistantly. There is also a slight grinding when I am accelerating or engine braking in any gear. All of the gears are intact and the synchros looked good when i looked the tranny over before installing it and there are no grinds when shifting into any gear.
Ill probably be taking it apart soon and ill be checking the countershaft bearing, Is there anything else that i should look for while i have the tranny out?
I forgot to mention that we also replaced the clutch and flywheel. Ive kept the same mounts and linkage that i had before so I wouldnt think that they would be causing the problem. Never had this kind of thing happen with the y7 trans.
