1 - 3 of 3 Posts
Will my ECU from the Y8 motor work for the z6? The Y8 is 1998 and the z6 is 1993 if that helps. Both are vtec as well. I also have a p2p ECU if it would work with the z6?? Someone please help me I need my car running
Civic turbo Hx/Ex
The y8 is obd2 and the z6 is obd1. If you're asking if a y8 ecu can plug into a z6 car and harness, the answer is no.
if you just swapped in engines, use the same sensors where you can. the dist wont plug in, so you will need a jumper harness......or you could swap the y8 head on the z6 and plug and play
1 - 3 of 3 Posts
