1 - 2 of 2 Posts
I recently damaged my oil pan on my Z6 and a friend gave me his Y8 pan; It went on without issues... but there was a difference though; I'm not sure what you call it but the layer was higher up in the z6 pan, and on the Y8 the layer was flush to the bottom of the pan. I'm running this pan right now, and every now and then on start up the oil light flashes and goes away after idling for a while.... think this could harm the motor?
i'm guessing you didn't use the y8 pickup? the y8 pan sits lower, so oil starvation is very possible if you don't use the correct pick-up. Don't drive the car until you change it
1 - 2 of 2 Posts
