1 - 7 of 7 Posts
sorry for being a anoying noobe... but i tryed to install a y8 manifold on a z1. install was a perferct
every thing bolted up grate. but have a nasty idle jumps from 600 to 1000 constently but revs a hell of alot better AOLT!. do u think i may be runing to lean dew to the massive air flow?
96,97,00 civic
Yes it would work. It's from a manual right. IACV holes need to be present. If your idle is fluctuating you might not have gotten all of the old IM gasket off which may have caused a vac. leak
P.s. If your not from the U.S. then your typing is fine. Otherwise please type so it's easier to read. Thanks
so u think its a vacum leak?
1 - 7 of 7 Posts
