1 - 2 of 2 Posts
Ok, so im going to be rebuilding and putting a d16y8 in my 91 sedan here in the next month or so...
Couple questions....
1. The car is currently a mini-me swapped car. y8 head, on a d15b7 block. Hasport obd1 conversion harness, and a p28. My question here is, i can just use the current harness i have, correct?
2. The y8 has, what im guessing, is a crank angle sensor. Its located near the crank on the drivers side of the motor...I do not need to reinstall this, do i? That is OBD2 thing, correct?
3. Anything else i should know?
peterbilt
yes use stock harness
no need for that sensor unless your obd2
i need to start reading thread b4 answering
1 - 2 of 2 Posts
