1 - 15 of 15 Posts
88 Hatch
okay guys got 88 hatch with b7bottom end and y8 head. i just picked up a y8 im. the car was running perfect before im. now the car will only start with starter fluid then die. i got fuel pressure 42 psi and brand new fpr. i am using the y8 fuel rail that came with im but the old b7 injectors i was already using. any ideas on what to check now? i assume the injectors arent firing.
88 Hatch
ya i got 12 volts to all four. no cel is being thrown either. however i did notice that one of the injectors on the nozzle side that little cone piece that goes around it was missing on one of them.
88 Hatch
yup got fuel also pulled the entire fuel rail with injectors still connected and it is spraying plenty of fuel
88 Hatch
ya before mani swap had b7 mani with obd1 dizzy and p28 ecu only thing i changed was the manifold itself. prior to changing manifolds had no issues. could i some how have a vacuum leak?>
88 Hatch
well i said they are firing now i am getting fuel and spark but still not starting except with starter fluid
88 Hatch
okay if i pulled the return fuel line off no fuel is coming out of the fpr where it connects to return line?? but injectors our spraying fuel. confused??
88 Hatch
Man i figured it out thanks so much to you. it ended up being fuel rail clogged with dirt. apparently the guy i bought it from didn't take care of it. took off the rail cleaned it all reinstalled and car fired up. thanks for your help.
1 - 15 of 15 Posts
