1 - 7 of 7 Posts
Will it work ok? I know there is a slight difference between the gears and such. Im just wondering if the cam and gear from a z6 head will fit and work ok in a y8. I cant really pass up the deal on the cam and gear.
C
if its also a y8 block... and you have an adj cg advance 4.5 degrees... that should help out... what cam?
Cool User Title Here
Z6 cam and cam gear,read his topic title
Install cam and gear, set to TDC and go, its only when you mix and match cam/cam gear that there is a timing issue
Im not sure what CAM is it..I know its not stock. But it is for a z6. and so is the gear. the block and head will be a y8.
Thanx for all the help. Its sites like this that make me want to keep my lil sohc.
1 - 7 of 7 Posts
