compression ratio? I searched only found ratios on different blocks not the y7
G Guest · Discussion Starter · #1 · Dec 29, 2003 compression ratio? I searched only found ratios on different blocks not the y7
S soccaian · Registered Joined Sep 18, 2003 · 301 Posts #2 · Jan 1, 2004 Only show this user i believe this will put you somewhere in the neighborhood of 9.4-9.6:1 compression....
G Guest · Discussion Starter · #3 · Jan 2, 2004 c-speedracing has a good compression calculator as well as a few on google if you search for them.
