1 - 20 of 27 Posts
2000 Civic
I'm planning to bolt a y8 head on my boosted y7 block. wandering if there any mods I need to make to the block in order for vetec to work. Any advise would be sweet. thanks
OMG TOTALLY COOL TITLE!!!!
88 y49 crx
depending on the chassis its going into there might be some slight mods. also i dont remember if there was the oil restrictor on the block of my y7 when i did this. if there is then remove it and apply the y8 head. again depending on what car this is going into there "might" be some mods needed
Well?
if its an OBDII chassis than no there is no mods needed. Just bolt on and wire up VTEC
Well?
88 y49 crx
Yes, you need to first remove the Y7 head.
he's asking if he needs to make any changes to the block.
I'm looking into this too, as far as I know, no modification is required.
I got the question. There's nothing you have to do to the block except take the Y7 head off of it. I say this with 100% certainty.
2000 Civic
Thanks for the info. To clear up a few things, it's an EK sedan, with stock bottom end, arp head studs, comtek head gasket, air research t-3 turbo, dsm injectors, and factory ecu/tune (for now). I think I do remember seeing an oil block off plug in the block when I had the head off last. In the corner by where the v-tec solinoid gose. Thanks again, the heads at the machine shop right now. I'll let you guys know how it turns out.
I'm pretty sure, when you remove the y7 head... You're going to have to remove the oil jet plug on the y7 block to allow for the vtec to engage. And you've probably already switched from 3-wire IACV to 2-wire, so no need to go there.
Third time's a charm
I'll say this for the third time...
1.) Remove Y7 head.
2.) Remove head gasket.
3.) Install new gasket.
4.) Bolt on Y8 head
There is nothing, nada, gar nichts, zippo, that you need to do to the Y7 block before putting on a Y8 head. I'm not pretty sure - I'm fucking positive.
There is no oil jet on the Y7 block.
Hello, MacFly??!!! :hammer:
[/thread]
:bigrofl:
wrong newbster
he is 10000000% correct. the oil jet is in the head, its under the middle cam cap. ;) :TU:
'98 Hatch
i picked up a full mini me y7/y8 block from a friend working fine off an eg. it was going in to my ek but a friend on d-series gave me a y8 bare bottom block [no crank, pistons, rods]. should i put the y8 head over the y8 block? i was told y7 bottom internals go over right? planning to just go n/a with slight power. any ideas or suggestions appreciated.
1 - 20 of 27 Posts
