1 - 7 of 7 Posts
A lot
I am considering buying a built Y8 block, what issues should I expect when putting my Z6 head on it? Didnt take much time to search because Im trying to hurry.
no issues at all if its going in a obd1 car. plug an play. you wont use the plug by the oil pump. and use z6 or Y7 belt. and i think Y8 belt to. But I know for sure the Y7 belt works..Its what im using on my D16Y7 built with Z6 head. works perfect.
See above...
Doing this "research" for a friend, so bare with me. To answer the OP's question, but using OBDII...what would one need to do? Conversion harness, OBDI ecu (P06, P28, etc), 3wire to 2wire conversion, anything else?
Thx
1 - 7 of 7 Posts
