Hey guys! Just checking if anyone here has experience with this combo, as I just bought a D16Y8 that had a mystery bottom end inside it. I am looking to run the following for a fun street NA build that can surpass 140whp, keep in mind I live at 6,000 feet elevation which lowers effective compression.
D16Y8 block
75 mm PG6B pistons (86-87 Integra D16A1)
H-beam rods
D16Z6 head, fully ported
SpeedFactory Street Savage camshaft (+11% intake and exhaust valve lift)
Rocket Motorsports springs and retainers
Adjustable cam gear
Y8 ARP head studs
Skunk 2 Pro intake manifold, port-matched
70mm throttle body
Z6 240cc injectors, flow matched
Longtube race header
Full 3" exhaust
Hondata S300 with flex fuel
This yields a 11.67 compression ratio on 3-layer head gasket, 10.47 effective CR with elevation. We have E-85 gas stations here. My main concern is PTV clearance (Piston to Valve). I will clay it up, but know things loosen up around 8,000 RPM.
Any input appreciated,
Thanks.
D16Y8 block
H-beam rods
Adjustable cam gear
Y8 ARP head studs
70mm throttle body
Full 3" exhaust
Thanks.
