H
does anyone know if you can build your y7 trans to y8 specs? if so what gears are diffrent/carrier? ring and pinion?
the y8 uses a large bearing case while the y7 uses a small one, I have no clue if you can build upon this.
H
is it easier to convert your y7 to a y8 or just buy a y8 trans and be done with it. this is what i have that i am putting in the car. fully built y8 with h beam rods/srp pistons/lightened crank/sleeved block/fully balanced/lighten flywheel. head-fully ported/o.s. valves/ti retainers/springs/cam/slotted cam gear. i am going to put a turbo on this later and from what i hear the y7 is shifty and blows apart. is this true? any help works for me.thanks
Cool User Title Here
Easier?? Hmm...lets think about this, take off a tranny crack it open, swap shit around...OR
Take tranny off, put tranny on...
Its a no brainer, complete swap is easier....and probably cheaper
There are slightly different sized bearing in the y7, however its just as strong as the y8. In fact (and I probably do not represent everyone on this), I see more y8 trannys with internal issues than y7's
Ive seen the opposite lately around here.
The y7 has some longer lower gears...and would pull a little bit more in the bottom end.
I mean...oops..
the y7 has longer gears...the y8 has the shorter lower gears..there we go..
not worth the trouble. Y8 or nothing.
Unless your planning on running 3 miles on the dry salt lake beds, then we'll talk!!!!!
