1 - 10 of 10 Posts
Ok I posted a question about my build what i will be running is
I/H/E
y7 block
y8 head stock minor P&P
a6 pistons
obx intake mani
b16 or b18 Throttle body
what will be est whp
what will be est c/r
what head gasket to use
will i need tuning just for this setup
one day i thought i might throw around 5psi boost in on this setup
will there be major problems with compression and 5psi on stock internals
help with this question on tuning
5psi on stock internal is nothing lol :beer: .....dependind of your compression ratio! 5 psi on a 10:1 cr is ok but if you already have 12:1cr, I dont recommend to boost....
what is the c/r of y7/y8 with a6 pistons
and will 5psi be ok then
what about tuning on all motor until i turbo
N
Yo guys,
im new here and im building a D16y5, cuz i burned out the rod bearings in my ZC SOHC VTEC. i still have the head for my ZC cuz its as a fully ported. i wanna put this head on my D16y5 block. what head gasket do you suggest ?
1 - 10 of 10 Posts
