Its a used kit and the selenoids look like the ones in the picture but the guy that sold it tome told me that one is the nitrous selenoid and the other one is for the purge (it even has the purge tube atached to it) and gave me the button for the purge. He told me that that was the way he had it hooked up.Im betting your fucking up a good safe nos dry system with two nitrous solenoids in which case you are going to kill your car quick.If its the kit im thinking of it has 2 solenoids and a fpr in the middle not 1 solenoid and 1 purge valve.
I sold my kit to a guy explained that shit to him and he went out and fucked his motor since he decided the other one was for a purge and that he didnt need the fpr either.
This is how dry kits get their bad rep.If you run just the one solenoid and not the fpr you will kill your motor most likely the first time.
ngk bkr7e
he didnt give me any fpr with the kitIm betting your fucking up a good safe nos dry system with two nitrous solenoids in which case you are going to kill your car quick.If its the kit im thinking of it has 2 solenoids and a fpr in the middle not 1 solenoid and 1 purge valve.
ngk bkr7e
will it be better to buy the parts I need to make the kit right or to buy the nos dry to wet conversion kit and make it a wet kit and then use the second nitrous selenoid for the purgeIf you don't have the other parts in that picture then your easiest bet would be to convert it to a wet kit.Go to jegs.com or summit racing and buy the fogger,line and jet needed.
If it only has one solenoid to spray juice and thats it do not use it.Like bone said it adds fuel pressure to the factory fpr via its own fpr.(the blue thing in the pic)You don't use that and it will not have a way to add fuel.
jegs also has the fpr to make that kit right. To make it right as a dry kit you need the nos fpr ,a special nos t fitting and a fuel jet.
