1 - 9 of 9 Posts
Curious George
'99 LX Civic Sedan
Does y7 clutch disk and pressure plate, will fit with y8 tranny and y8 flywheel ?
thank you
E
yes but i would suggest upgrading the clutch now if you plan on mods later (just something you will have to do anyways)
also with some Y7's might wanna check if you have a 200 mm clutch disc. If so I HIGHLY suggest not using it!
Wait, no one ever mention some Y7 HB's had 200 mm discs??????
"Bone knows"
Curious George
'99 LX Civic Sedan
flywheel of y8 and y7 are the same ? only clutch disk may be different ? or pressure plate, and everything else if it's 200mm ?
thank you
just the clutch plate.........
ever notice how wide the pressure plate is??????
200mm disc rides in the inside 3/4, 212 mm disc rides on the outside 3/4........
so why not make full width disc??????
Curious George
'99 LX Civic Sedan
never noticed, I never replace y8 clutch !!
only y7 ! I'll notice for sure :)
thank you ! :)
64.233.227.168
any d sereis clutch, pressure plate will swap with any d series
same thing goes with trans missions as long as u dont swap frm cable t hydro then ull need a bracket
what in the hell you talking about????????
Let me see you TRY to stuff a 90-00 clutch disc into a 88 pressure plate/flywheel Civic/CRX combo.
Also your MIS info about swapping between cable and hydro, no ONE bracket gonna make it fit. I guess the speedo cable plugs right into the 92+ VSS electrical connection also???????
Curious George
'99 LX Civic Sedan
L O L !!!
People who don't know are OK when they wanna know the truth !
People who explain something they don't know to others are bad. Really bad.
Final point !
1 - 9 of 9 Posts
