Boost Gets You Laid
Del Sol
There is a 89 hatch 4-speed f/s localy that I am takign in to consideration.
My plan would be to take the y7 out of my Del Sol (currently an auto trans) and put it in the 88 Hatch.
Would I use the 88's d-series clutch and flywheel?
As stupid as the question may seem it's just a reassurance thing for me. Want to make sure I buy the correct shiz for this swap:TU:
Lifetime Awesome Member
'89 CRX HF
if the clutch in the '88 is still good, use the flywheel and clutch from the 4speed
if you want to bump up to the 212mm flywheel, then you dont want the '89 clutch/flywheel
Boost Gets You Laid
Del Sol
Discussion Starter · #5 ·
I'll rock a y7 with a 4speed for a while lol.
If I'm not pleased with it I'll bump up to a later model ex/si trans at the end of the summer
Thanks guys :TU:
