1 - 6 of 6 Posts
00 civic
y7 mani swap to y8- injector Q
i read the post about swapping manis and it said the y8 injectors with a y7 ecu wood run rich but autozone sells the same injectors for both y7&y8. the reason i ask is because i swapped manis and my car ran like crap so i swapped injectors and still get cel of to rich or lean? is there anyway to physically tell the difference in the injectors ..... identifing markings or part numbers on the injectors them selves.. thanks for all the input
00 civic
thank you for the info but i dont understand why autozone sells the same replacment injector for both y7 & y8
Curious George
'99 LX Civic Sedan
You have to keep y7 injectors with y7 ecu anyways you've replaced the intake manifold.
If you want I got set of y7 ones in really good shape !! make me an offer.
1 - 6 of 6 Posts
