So I did a motor pull for a rebuild and dummy me never labeled the coolant and vacuum hoses for the IM, its a stock Y7 not a swapped one or anything. Is there a diagram I can go by to help me I can't find one anywhere online. thanks
Pew Pew!
EJ6
Since im at work and cant edit a picture for you imma really try to describe it to you hahaha.
The two ports on the TB is the coolant.
The first coolant line connects from the left side of the intake manifold where it " T " off from the big coolant hose.
The second one coolant line comes up from below the Intake manifold. the tube near the PCV vale.
The two other ports BELOW the TB are vacuum.
The first port I believe is the EVAP [ not sure of the actual name haha ] its that little small black sensor that connects to the catch can.
The second port is for the PCV Vale.
Hope it helps.
