1 - 3 of 3 Posts
I was hesitant to post this in fear of flamage, but I need to know. I searched a bit, but couldn't find a definite answer.
What do I need to do this head swap?
Headgasket from y7?
Timingbelt from y7?
Headstuds from y7, one from z6?
Cam gear from z6?
Is this about it? Is it correct?
Thanks in advance for any help.
Either one from the y7 or z6 timing belt and head gasket will work. Yes, you'll beed 9 y7 head studs and 1 z6 head stud. Use the cam gear made for the head unless you're using a 1.5L block then you'll need the y7/y8 or adjustable cam gear
1 - 3 of 3 Posts
