1 - 9 of 9 Posts
ok so i found a y7 block with 80k for $50 so i bought it
i have a couple questions ... after seaching i found nothing .
y7 block a6 head
* Which head gasket should i use?
* Which timeing belt ? I have a adjustable cam gear
* Which arp head studs?
* Which Rods ? i got like 20 diffrent awnsers
I will be running vitara pistons
Might sound stupid but i need yalls help Thanks
Use a Y8 head gasket, timing belt or head studs I'm not sure but you will have to add the A6 oil restrictor to the block, you can use any D16 rod you like.
FF Misfit
y7 block a6 head
The rods are a matter of personal preference and opinion. For the headgasket use the metal Y8. As for the timing belt, you should be able to use the y7 timing belt since the deck height of the a6 and y7 is the same. As for the head studs, I'm pretty sure you'll need to use the A6 studs.
ok ,i like the TT rods .would i get the ones for the y7?
add the A6 oil restrictor ? whats the diffrence?
thanks yall
FF Misfit
thanks yall
Ya, IIRC all the 1.6 rods are pretty much the same specs so any TT rods should work. As for the oil restrictor, since you're using a notec block and notec head, I don't think it's necessary.
The Y7 is more like a VTEC motor without VTEC than a traditional noTEC motor. The Y7 has the restrictor built in like a VTEC head, you'll end up with too much oil in the head without one.
cool thanks ... any thing else i should know?
FF Misfit
Good info. I didn't know that. :TU:
1 - 9 of 9 Posts
