1 - 2 of 2 Posts
Looking to grab a Z6 or Y8 intake manifold (not 99-00) that has been cut open and cleaned up.
Would love for the rear IACV to have been blocked/welded, and make some more plenum room.
If you activly can do something like this as a service, PM me. I am open to discuss other modifications I have in mind.
Mostly interested in getting cleaned up runner mouths at the plenum, and a bigger TB throat.
Will be running a K20A3 62mm TB on a bolt on adapter to allow a bellmouth shape to be used, if the manifold's throat is opened to 70-74mm.
I believe the biggest throtat is around 80mm once you block idle ports.
Let me know gentlemen.
I decided it was worthless to get my d17 tuned on a fully stock setup when I can easily do a d16 vtec cam/valvetrain, and run a much better intake setup.
Goal is beefing the shit out of the midrange from 2000-4500.
Discussion Starter · #2 ·
Can close, changed my goddamn mind again.
Figured out a different setup that will allow me to maintain my factory harness without adapters
1 - 2 of 2 Posts
