1 - 20 of 29 Posts
Disclaimer: The following is provided as a GUIDE ONLY, and neither myself, d-series.org nor Underground Imports take any responsibility for the outcomes of someone else doing the following. You follow these steps at your own risk!
Aim:
To fit a WHITELINE 18mm Rear Sway Bar to eg5 HB.
Required:
- Sway bar
- 14mm ring spanner/ratchet
- 12mm ring spanner/ratchet
- Grease
Info:
Ok time to really upgrade the susspension on my eg. 18mm is the largest sway bar u can fit to an eg without heavy duty mounts and what not. This bar just happened to come up for sale when i was floatin by so i promptly bought itm massive difference. Heres the fit. Very Simple.
Step 1:
OK jack up the rear of your car and take off the rear wheels, u should probably use jack stands too.
Step 2:
OK now undo and remove the 2 x 14mm Bolts on the left and right LCA's.
Easy.
Step 3:
OK with those undone and out of there u must remove the 2 x 12mm bolts on the subframe, there are 2 on each side so thats a total of 4 x 12mm to undo.
Step 4:
Ok now pull out the stock toothpick, i mean sway bar, take of the clips as u will need these for the next bar, put some grease on the rubber mounts and clips and put the bar back on. Just finger tight the 12mm bolts to hold it on.
Step 5:
Now with the bar on, line it all up, i suggest gettin all bolts started and then centering the bar and then do up the 12mm bolts tight, but no donkey kong tight!!
Step 6:
OK now do up the 14mm bolts on the LCA, remember not super tight like donkey kong the bogan!!!
Step 7:
Ok now, put the wheels back on, lower ur car and check its all tight and sturdy and your done.
I also have a cool title
Top Aussie said:
lol NO its too bad u dont have an eg man ;)
I would trade in my car for an eg but ive put so much into my car plus its a daily driver. i couldnt just give up what ive done to the car so far. Quit making me feel bad for having an ej8 :(
CR-Vtakin
your mom
98CiviCn00b said:
Too bad u dont have a EJ8 or an EK.....You woulld really help me out.
werd, then you could be in the eg squad Dave.
nice shoes trav
nice sway bar too, I just have 14mm gsr bar on my hatch.
CR-Vtakin
your mom
Top Aussie said:
no that was my mate u fuck!!! :haha:
you dont got to lie to kick it codlips!!! :smile: you forgot your sandals at the beach huh?
1 - 20 of 29 Posts
