1 - 20 of 48 Posts
Disclaimer: The following is provided as a GUIDE ONLY, and neither myself, d-series.org nor Underground Imports take any responsibility for the outcomes of someone else doing the following. You follow these steps at your own risk!
Aim: To fit a Carbon Fibre Js Racing intake to my eg5 HB.
Time: 1hr or less
Required:
- 10mm Ring Spanner/Ratchet
- Standard Screw driver
- Phillips Screw Driver
- Js Intake
- 1 Nut/bolt/washer
Info:
Yo with much who har and what not around this intake i took it upon my self to get one in and fit it, simple to do, here is my guide, pretty easy too.
Step 1:
Ok pop your bonnet so we can romove ur existing intake. Min happened to be a sexy JDM eg6 SIR stock box and pipe, i shed a tear. Simply remove all teh hoses hangin off it, remove the clamp on the throttle body and also teh 3 10mm bolts holding the box to the body.
should look like this when its all gone:
jdm vs js:
Step 2:
Ok now time to put the intake together, but on the rubber reducer at the Tb end on with clamp. Ok first we need to bend a brcket so u can fit the dam thing in there!!
Step 3:
You will have to reroute a coolant line just near your fuel rail. You DONT have to but if i leave all that pipe lying around i could rub on your intake and wreck it, simple as a re reout and a joiner
Step 4:
Ok now that thats all sorted, fit the intake pipe minus the filter, itll eb pretty tight in places, but it should fit, even with a strut bar.
Step 5:
Ok now fit the filter and use the rbacket provided to make a intake stay. this is who i hooked it up and it is very sturdy, i migth change it later, when i build an air box and what not, but this was i didnt need to mod the bracket and/or make another one. it was included. BTW i removed the cooland resevior just to get a lil but of extar room.
Step 6:
Ok now tighten all teh clamps nuts and what not, rejoin all hoses and giev it a quick shake to make sure everything is all tight and stable. then reset your ECU. remove the ecu fuse out of the fuse box and leave for 10mins.
Step 7:
Put ecu fuse back in and start ur car and let idle for bout 10mins and dont touch anything!! no revs or anything!! onces it warm, go for a squirt and make sure all is in order. Recheck all clamps and fittings after a 'spirted drive' to ensure all is stable and well.
Good luck and well done.
COMING SOON: MAKING AN AIR BOX FOR YOUR JS INTAKE!
i love the whale penis hehhe
CR-Vtakin
your mom
WOG PENIS!!!!!!!
nice intake Trav, nice write up also. I am curious to see this airbox you are going to McGuyver up, are you going to use sheet metal?
1 question y did u take out the ECU fuse to reset the ecu y would u do that??
Shackle me NOT!!!
1995 Honda Ballade
trav.......I really dig your DIY's.............I dunno if I should laugh or go out and buy a fake j's intake.....................good write up.......:TU:
you're a funny bogan
Shackle me NOT!!!
1995 Honda Ballade
LMAO?...........get one.........HELL no, I've had something similar and it's way too noisy, plus I lost torque.
1 - 20 of 48 Posts
