1 - 7 of 7 Posts
My sig is longer than yours
i suddenly got a leak from the oilpan, and im wondering if its from the pcv valve not working, causing pressure to build up and the weakestlink being the oilpan gasket..
Ranger - work truck
hmmmm, seems plausible....
definatley want an answer to this question myself.
Well, there like 5 dollars. just replace it and see what happens.
i thnk they are cheaper than 5 dollars! haha.
where's the oil coming from exactly? do you know? is it dripping from the drain bolt? from the oil pan gasket? sometimes it looks like it's leaking from one spot when it really isn't.
1 - 7 of 7 Posts
