1 - 3 of 3 Posts
would a td05h 16g need an oil restrictor? I see some oil blow by when the blowoff goes. Is the turbo shot, or is it just oil blowing past the seals from excessive pressure? It's not a lot of oil... just a dark puff.
If it is coming out of your BOV, think about where that ait is coming from: through the filter, tubing, turbo, and more tubing. Do any of those have oil in them? (Well, your filter might if it is an oil clother filter, but that wouldn't cause what you were seeing.)
The turbo is the only source of oil in that path. The exhuast isn't being routed through the compressor (I hope), so it isn't blow-by or anything that passes through the combustion chamber.
Turbo seals would be my conclusion. Time for a rebuild.
1 - 3 of 3 Posts
