1 - 14 of 14 Posts
Pew Pew!
EJ6
Is it normal for the angular bearing to be able to lift off the shaft from just a bit of tug?
And also is the needle bearing okay if it has a slight in and out play?
I was in the processes of just changing out my ISB and once completing that, I started to put things back together and just started inspecting things to see if everything is still decently okay and when I touch both bearings. They both had these symptoms that im describing.
Thanks for your time.
- Sammo
See above...
Yeah, as long as the play on the needle bearing isn't excessive you are fine on both counts. Just rubber mallet that MS bearing onto the shaft fully.
Pew Pew!
EJ6
Thats what I was thinking about the CS bearings but as for the angular bearing. Is it normal for it to easily be pulled with my hands wiggling it? Like I can just wiggle it ..1 ....2 and it comes up off the MS shaft.
Pew Pew!
EJ6
all is fine :)
92-95 EX/Si?
Yes sir.
I also took out my ISB that you said was the issue from my other thread and the bearing seems to still be okay, I still put in the near bearing though but just wanted to let you know hahaha.
But over all, IF it isnt the ISB that isnt making the noise that i am encountering then what else would your memory bank think it would be?
link to the thread/post, my memory bank is broken :(
I have found, as Aquafina and Bense that the older trannys (88-91) slide apart much easier, sometimes way too easy IMHO.
Pew Pew!
EJ6
http://www.d-series.org/forums/transmission-alley/133943-transmission-noise-bad-bearing.html
This be the link I mentioned.
And thanks fellas for the relief of good news about it being normal for that bearing to be able to slide out quite easily hahaha.
Lets hope when I put this together, the whining/ticking goes away if not then damn. Imma have to look for a spare trans to put in while I continue to rebuild this current Si trans...Oy, there goes my savings for a wideband hahaha.
Yea, most of the cable trannies I have had, that bearing on the MS just slides right off. Little effort to put on, but comes off without effort.
Certified O.G.
A Shitbox
Not a cable tranny good sir, hydro crap.
1996 Civic Type DX
It varies. Some come off just from turning the shaft upside down, some can be removed by hand, and some need to be pulled off (pressed off in my case as I don't use a puller).
1 - 14 of 14 Posts
