So since I have not been doing well with staying boosted its time to step back a bit and start over from the basics, kinda. The West Michigan Honda meet is July 15-17 and its a motivating goal to get the civic going again. I need to take a direction with a build for this car. Road racing has always sounded fun, and I'd like to do some auto x but I've never dedicated the time to go to such events but I'm hoping that this year is the year. Since I need to rebuild the motor again I've decided to just put a stock motor in the car and work on the issues I have with my car.
So here is the build idea;
Stock d16z6 with 102k (picked it up last weekend)
My rocket regrind cam (maybe swap valve springs and new valve seals)
Edelbrock intake with ls throttle body (have)
3" CAI with velocity stack
b series RMF v2 header (Put D flange on it and remove megphone)
ATI Dampner
Port oil pump
Open up oil holes in main bearing
New timing belt (reuse from turbo motor)
New water pump (reuse from turbo motor)
VW MKIV Injectors (have)
Sump the factory gas tank
Walbro inline 255lph
AEM Fuel rail
E-85, stock rev limiter and tuned by me
New 2jz Harness
215/45r16 BfGoodrich Rivals
What I already have on the car
Just refreshed Si trans with, carbon synchros, 4.437 FD, OBX LSD
Lightweight flywheel, stock clutch disc with eBay pressure plate
Traction Bar with tubes and rod ends changed last year
4 year old energy suspension bushings
Hardrace upper and lower rear control arms
rear disc brakes
Tokico Illumina shocks with ground controls 550r/450f
full 3" exhaust
small car diet
Here is where its starting
Its cold out and I hate the cold so I talked the Wife into buying me this.
I'd say its working well. It got up to 68 and I was sweating. Awesome lol
Starting to tear down the z6, throw away the junk keeping whats good.
The crank pulley bolt was really tight. Electric impact wouldn't take it off
After this I put the motor on the engine stand, removed the valve cover and drained the oil. It was super black but not shiny. So now it was time to turn the civic around so I can actually work on it.
I do not recommend the cheap movers from harbor freight. This was a huge pain by myself.
Turned around and in her corner. Just got to get the engine bay emptied out.
ATI Dampner
Port oil pump
AEM Fuel rail
New 2jz Harness
rear disc brakes
full 3" exhaust
small car diet
