Hi guys, ive just installed a d16z6, i need to know which wires go to the ecu. im using the d16 engine loom with a d15 cabin loom. ive been searching around, all i can find is which ports they go on the ecu. i need to now which wires, under the bonnet.
98 Civic Ex
If you don't have the car's wiring harness that previous had vtec then you'll have to run your own wires from the solenoid and oil pressure sender to the ecu. I did it by just cutting and soldering into my obd1 conversion harness. Try your best to make it clean follow he car's engine harness down through the firewall don't just have wires running everywhere.
Does that clear it up for ya?
