i have an 89 civi hatch dx, obd0 i also have an extra 92 civic hatch wiring harness completet front to back, i waqnna knoe if i can use thie obd1 harness and turn th dx hatch into an obd1 fuel injected, also have im, dizzy, comp,for obd1
Yep, unless you like to do a lot of wiring.it can be done but you will almost have to use everything from the 92 especially all the dash stuff (cluster, climate control, etc) to make it work
And fuse box. And that will make it difficult to hook up hte body wiring.it can be done but you will almost have to use everything from the 92 especially all the dash stuff (cluster, climate control, etc) to make it work
I think he is going to using the body wiring too. He said front to back.And fuse box. And that will make it difficult to hook up hte body wiring.
Your best bet is to modify your existing harness to include all of the new connectors and then use / make a jumper harness to convert the odb0 ecu plugs to odb1 I just did mine it was pretty easy! Just make sure you double check before you put it all in the car cause its a bitch to get out once you have a motor in therei have an 89 civi hatch dx, obd0 i also have an extra 92 civic hatch wiring harness completet front to back, i waqnna knoe if i can use thie obd1 harness and turn th dx hatch into an obd1 fuel injected, also have im, dizzy, comp,for obd1
