1 - 14 of 14 Posts
99' Honda Civic
I bought a new radio for my 99' Honda Civic EX. Being as stupid as I am, I cut the factory harness towards the very end cause I never thought I would ever use that radio again. So I was wiring the new one up and I came across a problem. There are 5 wires left from the factory radio and the new radio has only 3 wires left. Of course, the wires that I need to figure out are the Ignition (yellow), Ground (black), and the Battery (red). I have no clue where to hook those to though. The wires I have left from the factory are: yellow w/ red strip, white w/ blue strip, red, red w/ black strip and then a black one. Which ones go where?
· R2.....Zap Balls
94 Ex coupe
· FAMILY MEMBER #316
:stupid:
wow. to this day i dont know why people do that.
i mean, at least once a week i would have to repair someones factory harness. then the install would cost almost double. all because they didnt want to spend 20 bucks on a harness.
the best is when people think the universal color code on the back of the aftermarket radio is supposed to match the OEM colors.
· R2.....Zap Balls
94 Ex coupe
:stupid:
x10000000000000000000000. I used to hate it when I did installs and people would bring cars in like that. The best thing though would be the look on people's faces when I worked at Best Buy. If someone brought in a car with the harness cut we would charge them for a new harness in the car to replace the cut one, then for the one for the install, plus labor.
Harness adapters FTW. Unhook the factory radio and remove. Solder the harness adapter to the aftermarket stereo on your workbench (or dining room table! :) ). Hook the adapter to your factory harness and mount the radio.
Easy - and quick to return to stock.
PM
· Banned
heres the break down
red- switched 12v
yellow-constant 12v
black-ground
blue-power antenna
blue/white-amp turn on
orange-illumination
The rest are your speakers. you can fin out which one by taking a 9v battery and touching the leads to each side. Hope this helps a little.
Don
Somebody cut the harness on mine before I got it.. I will never understand why people just don't by the damn plug!! This really isn't helping you out.. I just needed to vent... lol
· Banned
Here is the setup for your car.. Hope this helps.
Don
+12V DC Battery(Constant) White/blue 47 7.5 amp Underhood fuse/relay box
Switched Accessory Yellow/red 28 10 amp Underdash fuse/relay box
Ground Black
Illumination Red/black & red
Left Front + Blue
Left Front - Gray/black
Right Front + Red/green
Right Front - Brown/black
Left Rear + Blue/yellow
Left Rear - Gray/white
Right Rear + Red/yellow
Right Rear - Brown/white
red- switched 12v
yellow-constant 12v
black-ground
blue-power antenna
orange-illumination
Don
Don
Ground Black
Left Front + Blue
it was taken care of
· Banned
Yeah the first post was off the aftermarket plug by mistake. Glad you got it done
1 - 14 of 14 Posts
