1 - 11 of 11 Posts
so when im leaving the bar tonight, I push the passenger side window button to roll to the window down(power windows) and the window went all the way down... no problems, but when I tried to roll them up when the window gets close to the top itclicks and hops around.... wtf is the problem here?
well my friend soundz like you have a broken or a couple broken teeth on your regulator the last 2 to be exact common on hondas which wont allow the window to fully close and stay east to replace get one from the wrecking yard or ebay fairly inexpensive
you were correct... I replace the regulator today.. works awesome now... I even greased the side mouldings to help the window ease better... :) Thanks for all the input guys! :TU:
awsome good job!
Aye keep them runners greased...
My windows have popped out the runners during winter.Makes the drive to work a bit chilly to say the least!
Honda Civic
So I recently found out I have powers to bring things back from the dead.
Would this fix apply to rear windows as well? Mine is up but if I hit the window switch up or down it just goes click click crunch click. But my situation is that this girl kicked my door a year back and I just now got around to looking at it. *closes eyes and grits teeth in an attempt to protect himself from the oncoming flames*
yours sounds worse take of the door panel inspect the damage it may just be jammbed but being jammed and continously pressing the window switch may have broke some teeth........ is the outter door bent in or something that may be interfering with the scissor assembly?
Honda Civic
well i took the panel off but therre is no way to reall get a good look and see whats going on. therew is like a snake-like thing coming off the motor that kinda spins when i hit my window switch. or at least thats whhat i can feel with my hand. i cant feel anything else in there.
Honda Civic
I got a better look at the inside of the rear door today. The area where she kicked it in isn't interfering with anything. I just cant get a good look to see if maybe the window is off the track. When I hit the button the window moves like a 1/4 or an inch and thats it. Help if you can.
1 - 11 of 11 Posts
