1 - 20 of 33 Posts
I plan on doing a vitara/eagle rod setup with ARP headstuds. The head i have is a y7 with a delta 272 cam, supertech valve springs, and a "stage 2 port port and polish"(what I was told). That's all I plan on doing to the actual engine. My goal is 400whp.
Now, that I've covered that. I currently have a small on turbo on my d16y8 but I'm sure it'll be too small for my future hp goal. I got a really good deal on a great condition garrett but the person didn't know much about it. Basically, even if it won't work for my application I can still make a decent profit.
Finally, my question. Will this turbo work on my setup? It's a Garrett T04b90, .60/.81, 54 trim. The part number is 409080-5009. Supposedly it came off a Allis Chalmers tractor lol.
I'm sure the exhaust side may be too large so my next question is, would it work on on a stock gsr aiming for 400whp?
Also, before I get flamed. I searched......alot. I found several LS guys using them but nobody seems to have the .81 exhaust housing. Also, i couldn't find a compressor map or I might not be asking.
Thanks in advance for any responses.
95 civic coupe
Should make great power but will definitely be a laggy turbo. If you're planning on using it for drags it will work. My turbo is a bit bigger than that
Discussion Starter · #5 ·
To be honest I really want it to be strong at roll racing. I have a 50 trim .42/.48 right now and I love how fast the boost comes in but I'd sacrifice it for more power.
If you had to take a guess when do you think boost and start and when do you think I'd have full boost?
Also, what turbo setup you running?
95 civic coupe
It'd hard to say you have eagle/vitara which is really low compression, and if I have to guess you're full boost would be around 5.8/6k
I don't think it'll ever actually spool - that 64mm exducer is bigger than the stock exhaust pipe on a civic!
the compressor side is good for that 400whp, the exhaust side closer to 800whp...
I dunno why you cant find a 54 trim compressor map, they're all over the internet? granted its t04e vs t04b but close enough
Discussion Starter · #8 ·
Well I was looking for a compressor map that was really close to my specs. Anyways, could I get a different exhaust housing? Also is the exhaust wheel too big also?
95 civic coupe
Sell it and buy a turbo that's proven to work with vitara set-up. I'd suggest a Garrett 57trim 63ar I made a bit over 400whp with it and can be purchased new far $680
Retired From Hondas
The housing isnt your issue here. You have a huge snail and low compression.
Even with high compression this wouldnt work.
What is the car being used for?
Discussion Starter · #15 ·
Mostly roll races. Probably highway pulls. 1/4 Every now and then. I want to be able to compete with some V8s from a roll basically. The intake side seems normal. It's basically a 2" inducer/3" exducer 54 trim. The exhuast side is 64mm and 7mm.
Retired From Hondas
If you want 400WHP, than you need to look for something that flows around 45-50lbs/min..
But I would def have a comopression around 9.5 for response.
That turbo will work for highway roll racing. Expect 25psi around 6000rpm and it should carry well up to 9000+ rpm.
The large turbine housing is what pushes the power up the RPM band. If you put a smaller housing (like a t3 48 ar) it could make higher boost at around 5000rpm but choke out around 7000rpm.
Discussion Starter · #20 ·
Ok, thanks guys. To be honest 400whp is probably a little much for what I want but we'll see what happens. I'd probably be happy around 350
1 - 20 of 33 Posts
