8
Ok i have a SOHC VTEC (d16z6), and i have a DOHC ZC tranny sitting here, will this bolt up to the z6 no problem? or will i have to make modifications to get the half shaft to work correctly? I already have the half shaft and full shaft by the way! Thanks in advance!
you'll have to drill/tap the holes in the Z6 block to accept the intermidate shaft.
Most Z6 blocks are drilled, just not tapped. ALthough I have seen one not drilled OR tapped.
