You could probably make it work, but it definitely isn't plug and play. Are you also asking about the evaporator? If so then I would say that would be your biggest problem and a no. You would probably have to make custom mounts for the condenser and the pipe/hoses to the evaporator case may not reach or be to long, and there shape is a little different so there may be something in your way with those.
