1 - 4 of 4 Posts
S
will it? or will it only work on the y8 head for doing a mini me
N
no, If you use a vtec head you have to use a vtec dist.
B
You can use the A6 dizzy.... I have.... but you will need to still be using the A6 ECU. The reason Im not using the Z6 dizzy is cos I need the ECU to match.
BUT, you will need to bodge the A6 dizzy as it needs to be advances by about 20 degrees or so from where it sits on the A6 head! :)
Ben
1 - 4 of 4 Posts
