1 - 2 of 2 Posts
Honda
I have two engines. D16Z6 and a d16y7. Z6 is for parts.. Will the Crankshaft?/oil pump and oil pan from the Z6 work in a Y7 block?
\/Your Mom Was Here\/
Vibe GT
The Z6 oil pump means 2 things, you won't have a dipstick anymore and no crank sensor for the stock ECU. Also to swap the pan you also would need a Z6 rear oil seal holder because it's shaped differently.
1 - 2 of 2 Posts
