1 - 7 of 7 Posts
Ok so i have a plx wideband...
I read the instructions off there site and are kinda confused. I also tried to search but it is still all just jumble. How would i hook up the wideband if i had only one o2 bung spot? that is my question please help and thank you
The narrow band output wire on the WB02 goes the o2 signal wire at the ecu.
De-pin and butt connect a pin to the wire instead of slicing. Cleaner, well maybe not cleaner, but its better then hacking up the stock underdash harness.
02 signal wire= white d 14 on the ecu plugs (pin d is the second biggest or the one on the opposite side of the first biggest plug.)
You could always go buy a bung for about $5.00 and have it welded into the down pipe then install the WBO2 sensor in it.
Wouldn't that work ?
yea but im kinda super strapped for cash and time....
so i would take and hook up the power and ground and then hook up the white wire to the 02 wire...and isnt there a grey wire on the wideband to? what do i do with that
nevermind i got it thanks to all
1 - 7 of 7 Posts
