1 - 9 of 9 Posts
1999 Civic hatch
Hey all
1999 Civic DX
1998 D16Y8
1998 EJ8 tranny
The motor pulls fine and it runs decent. I had it with a Y7 TB w/ Z6 rotor and it idled at ~1600 and fluctuated. It was really annoying, but it drove fine. I installed a Y8 TB and ever since then, it idled fine (~1000) but when im driving and say Im going a steady 40MPH, it starts bogging and sputtering. RPM's don't fluctuate, it just sputters and the exhaust sounds like its spitting. It accelerates fine and revs like its supposed to.
Any tips on that?
CELs I have:
-IACV
-Second o2 sensor
-ECU malfunction (ECU works fine btw)
1999 Civic hatch
The TPS? I have a new Blox one, but its on the Y7 TB. The Y8 TB has the TPS but its riveted on.
I no longer haz teh pink eye! Iz got STINK EYE
ya if the TPS has a flat spot on the resistor bar the voltage can drop out the the ecu flips out. just an idea, oh you can take those out just gotta either drill the bolt or cut into it with a dremel then use a flathead to take it out thats what i did. one way to be sure is to hook up a DSO to it if you know someone who works in a shop who has one to check it out.
92 Civic Hatch
Exactly what this man stated!
1999 Civic hatch
I took my Y8 TB to get the TPS grinded off and I installed a new Blox TPS and it still feels the same. So that marks off the TPS as a problem.
1999 Civic hatch
Ill try out a new IACV next week. Hopefully that solves the problem. The *vroom vroom vroom vroom vroom vroom* when I hold the pedal at 1600RPM is still there with both TB's and both TPS'.
96 Civic HX
Did you calibrate the TPS? You can't just install one. That could be your whole issue right there now. They need to be calibrated using a volt meter aka multi-meter.
yes make sure you calibrate the tps, should be around .45v at closed throttle and 4. something at WOT. their should also be a 5v reference, and a good ground to the tps as well.
1 - 9 of 9 Posts
