1 - 2 of 2 Posts
Iv got customers 2002 focus with no turn signal rear wiper and the chime sound does it at wrong times or not at all as well as other sensors connected to gem.
I have reset the gem by disconnecting battery and was able to get turn signals wiper and chime to all work correctly but soon fails after a brief moment. This is also true with communicating with my scanner once the others fail i cannot connect to the gem only with my scanner all other module scans work.
I have checked the grounds they all are good going to the gem.
Here are screen shots of the codes that i pulled before it shuts down. everything says failure, so im guessing its internal to the gem?? i have no idea as iv never seen one good bad before. let me know what you other techs think
When I worked as senior mechanic for years, I replaced enough of them to know they are prone to failure and are crap.
When you replace it write down the numbers on the module. One of them is the new entry code for the door keypad if the car has one equipped.
1 - 2 of 2 Posts
