1 - 20 of 21 Posts
D
which cam is better z6 or y8
Stock Specs for D16Z6 SOHC VTEC (92-95) 304 / 303 212 / 204 394 / 373
Stock Specs for D16Y8 SOHC VTEC (96-up) 288 / 292 218 / 204 397 / 367
if i am thinking correctly a z6 cam looks like a better cam or am i not reading it right
D
yes but i want to put the z6 cam in a y8 head it looks like it might be a better setup
D
the head has to come off anyways cause it is warped. and i just want a little bit more of a gain. nothing special.
gloryhog said:
If you had a little extra cash, get a zex, or crower cam and that would be well worth it!
stay away from Zex cam they are noisy. Crower's are good. and of course you should consider the AKMEE valve train kit. :) http://akmee.com/sohc-vtec
Frank, look on Larry's board when I reported the base circle numbers as to why they where noisy.
I'll take a Zex or Crane cam first :)
Crane 251-0016 doesn't need springs or retainers, yet makes 155-160 WHP in NA on a D15 small valve motor.
Yeah, lets call Laurie @ Web and ask for the secret .480 lift cam :)
OG Hybrid folk.......where it started
Cool User Title Here
ghettoracer said:
makes power with no noise. :D
I don't get it. My zex was far noisier than the Crower stage 2 EVER was. Do you all know how to adjust valves??
Lets not, and just say we did
personally, i'm a fan of the z6 cam imy auto y8. only cause it's an automatic. i've run that cam for a good while and it's run bewtter e.t.'s than anything else i've run. even civic4ges stage 1 zex cam.
kulo said:
who has zex stage 2 for the z6 & y8, is it ok to run with stock valve train or change them?
This subject has been covered many times, the search button is your friend. But to answer your question I would personally get the valve springs to be on the safe side...
1 - 20 of 21 Posts
