1 - 6 of 6 Posts
1
Im hoping for someone to give me a compression ratio.
This will decide for me whether or not I go 16 pounds of boost or a 150 shot.
Setup:
A6 head, milled .040
A6 block with SRP 9.5:1 pistons
Now, I think I really want to go with boost, but feel my compression may be to high
If anyone could help me out on what headgaskets are available, the cheaper the better as I know people blow them quite a bit, but the more I can lower the compression safely will help me, I also have aftermarket head studs
I am limited to 93 octane and this will be my first F/I setup, if the comrpession is to high for DD on pump gas then Im just gonna go ahead and spray a direct port 150, cheaper, probably faster in the 1/4 but wont always be there
Hard decision, LMK
Thanks
1
cmon, someone tell me how low I can get this compression cheaply
Boost VS JUICE is on the line here
1 - 6 of 6 Posts
