White 98 ex coupe W/Y8T
723 Views 0 Replies 1 Participant Last post by  Mamalakis_made
Wheel Tire Car Land vehicle Vehicle
Tire Wheel Automotive parking light Car Land vehicle
Automotive parking light Car Wheel Automotive side marker light Tire
Hello pleased to meet everybody and share with the community.
My name is Yianni
I will try to add some pictures and give a detailed build list for my 98 ek civic. Thank you for checking me out. The car is tuned on E85 and is almost fully built for a street car. I have yet to get a 1/4mile. Please do leave me your thoughts on my build and what i should do next or what you would do differently. Hope to hear from everybody soon, enjoy the set up!!
Engine and turbo set up
-D16Y8 stock crankshaft polished
-Spdfcry no notch long rods/76mm vitara pistons
-BC valves, valve spring, and retainers
-Delta 272-2 cam i believe from jon at delta
-VMS camgear
-HKS clear timing cover
-Cometic headgasket
-FIC 1200cc
-AEM fuelrail
-Skunk2 intake manifold with stock Throttle body
-Fullrace ramhorn T3 turbo manifold
-Tial 44mm wastegate
-Greddy type FV 38mm blow off valve
-Straight down pipe
-Cheaper ebay intercooler piping and intercooler
-Hondata 4 bar map and 4 port boost solenoid
-Hondata ecu chip in a p06 with jumper harness
-d15b7 distributor with obd2a to obd1 jumper
-The turbo is from a friend and he had it on a car that he got from a friend. So idk how old it is or anything specific i do know i put a real Garrett housing on both sides and it seems to be holding up perfectly fine.
-Cusco catchcan
-Skunk2 radiator
Transmission
-Recently installed an Mfactory LSD undriven yet
-Stock axles for now i have alot of spares
-Stock gears
-Clutchmastwrs fx400 i think or fx500 i forget
-solid rear shift linkage mount and a poly front mount
-VMS short throw shifter
Suspension/Brakes/Wheels/Tires
-KYB AGX struts and coil sleeves
-Blox front 26mm swaybar and endlinks
-Stock front control arms
-BWR rear lower control arms
-Rays 16x8 wheels for the daily riders on nitto neogens 205/45
-Buddyclub P1 pair with 23x7.5R15 drag slicks
-Scarebird brake rear conversion bracket
-Full integra rear disc brake
-Megan racing traction bar
-Megan racing subframe brace (not installed yet)
Cosmetics
-Painted championship white 8 years ago
-Front lip on my stock bumper was ripped off recently
-Blackwidow designs2000 fiberglass front bumper (uninstalled)
-5050 Taillights
-EP3 front aeats
-EP3 rear seats
-EP3 steering sheel
-Glowshift oilpressure guage
-Glowshift boostguage
-Aem air fuel guage
-Titan motorsports fuel preasure guage (installed on fuel rail)
-Guages are mounted on aftermarket A pillar pods and aftermarket cluster bezel
-Hood risers (not installed)
-Bumper ties
I am probably forgetting something but almost everything is done by myself i could probably say i have about 9-11k into the car over the year.
Tire Wheel Car Vehicle Land vehicle
Tire Wheel Vehicle Car Grille
Hood Automotive lighting Automotive tire Motor vehicle Automotive design
Car Tire Wheel Vehicle Automotive side marker light
Reactions: 2
1 - 1 of 1 Posts
1 - 1 of 1 Posts
