Hello, I've looked all over past articles and can't seem to find what is best to use. I have an A6 block, LS rods, 5mm over Honda P29's, and a Z6 head. What wrist pins should I buy? OEM honda? If so, which ones? Thanks for any help!
Sorry I wasn't more clear. I was asking about the manufacturer. Stock Honda ones OK or is there something better for near the same cost?
5mm over P29s? 80mm then eh? ;)
Pretty sure you mean .5mm, I'll give you that. OEM Honda is the best bet if you have OEM pistons.
I was pretty sure Honda sells the piston an pin as a set though...
