1 - 10 of 10 Posts
00' Honda Civic EX
Im trying to hook up my a/f gauge and I hooked the signal wire up to the green wire on the first 02 sensor (which is in the header) and the light for the a/f gauge only comes on when Im cranking the car...after that there's no more signs of it working at all. Was I supposed to splice into the white wire on the 02 sensor?
I believe the white wire goes into a dask light source...
tap into the wire coming out of your dimmer switch... use a VOM (Volt, Ohm, Meter) to check for the correct wire.
00' Honda Civic EX
Huh? I just need to know where to put the signal wire from the a/f gauge at to make it work. I don't need to know about the light lol
Cool User Title Here
So your telling him, to get his a/f ratio signal from his dimmer switch??
Tap it off the ecu, not sure what year car you have, but the a/f signal is generally a larger white wire on the last plug on the ecu
00' Honda Civic EX
I have a 2000 EX. So it's a white not a green one huh? I spliced it into the green one on the 02 sensor...should I have done it to the white one on it?
00' Honda Civic EX
I hooked it up to the harness. Thanks a lot though guys. I know for future reference now lol
1 - 10 of 10 Posts
