1 - 4 of 4 Posts
Well, I decided to swap my Auto to a Manual....I have a complete turbo kit and the onlything that was holding me back is I didnt want to run a piggyback system or FMU...I Just dont trust em. So I decided to go ahead and swap to a Manual....I just purchased a Kit on ebay that has
Clutch Pedal Assembly
Clutch Master Cylinder
Clutch Fluid Reservior
Brake Pedal
Clutch Fluid Line and two mounting brackets w/ hardware
So What else would I need? Which Tranny and ECU Would you recomend? My car is a 2000 D16Y8. I Want it to look factory so i know i will need the middle console.....Thanks for the Input!!
The tranny's from the 96+ EX seems to have the best ratio. But you are boosted DD any 96-up ex tranny would be fine
Discussion Starter · #4 ·
Thanks Guys!! I was looking at the automatic Console ...and im sure i can make it work....and still look factory....Is the P28 Just a Plugin or will i need to modify the harness.....Also does anyone have some DIY's on This? Thanks!
1 - 4 of 4 Posts
