1 - 2 of 2 Posts
G
i know if you match a d16a6 block with a d16z6 head...you use a d16z6 timing belt. But if you use a d16a6 block with a d16y8 head then which timing belt do you use?
are the d16z6 and d16y8 timing belts the same?
G
Discussion Starter · #2 ·
match the timing belt with the head you use. I believe the belts are different. one has more teeth than the other.
1 - 2 of 2 Posts
