1 - 18 of 18 Posts
im gonna be puttin together a d15 soon and i want to know what honda/acura rods and piston will work in d15b1,b2, and b7. compression ratio doesnt matter to me, im not sure what oem parts will work tho. help me out?
all d but d17 i belive but with certian combos you can get a comp ratio of 140:1
well you can get alot of different compression ratios
try searching zeal calculator and play around with it
1.6l rods will not fit into a d15 block. just run stock d15 rods
will fit
just super high compression
correct me if im wrong
Discussion Starter #18
im tryin to stay non vtec. i like the low end torque. i reawlly dont wanna do the same z6 drop like everyone or the a6 drop
1 - 18 of 18 Posts
