1 - 4 of 4 Posts
9
Has prolly already been asked but whats the d-series to turbo? Ive asked around and alot of people are sayin go with an ls or b16 but i wanna stay single cam what would be the best motor to go with? Its going to be my daily driver and i plan on running a t3 and i want to boost at least 7-9 daily? what should i go with?
9
now running a turbo is it better to have vtec or not. I mean when the turbo bows out at high rpm is it better to have vtec for the higher rpm range
overlap at the cam is bad for a turbo (because all the air gets forced through the exhaust instead of staying in the cylinder). I think the stock vtec cam doesn't have much overlap, so you're fine with using it. Bigger lobes means more air getting into the cylinder. With an a6, you'd probably need to get an aftermarket cam. But, honestly, your turbo selection and tuning will make much more of a difference than the cam for a turbo setup i believe.
so either one is fine.
1 - 4 of 4 Posts
