1 - 4 of 4 Posts
S
car info
96 hatch
TD04 turbo
front mount
6lb's daily
10lb's race (until engine build want to boost 16-20lbs race then)
450dsm injectors
emanage with injector, ignition harness
i have about $500 bills to spend, im looking at a boost controller, i have 3 choices.
1. Profec E-01 or
2. Profec b spec
3. Apexi AVCR
now i have a emanage so i am leaning towards the E-01 but i dont think ill be messing with the tuning capablities that the E-01 can do with the emanage, the b-spec is noce cause of the price, ill have some change left over for lunch :lol:, i dont know much about the Apexi but i have heard great thing about it.
im torn right now, so what would you do?
O
turbosmart dual stage controller $229 from www.fast-turbo.com
you can wire in a button you press or rpm activated switch to controll switching fomr low to high boost. it's hard set so you don't have to worrie about spikes as much. I normally don't like manuals, but this particular unit is a awesome unit, it's the one i have chosed to use with my car's setup.
D
The one thing I really like about the AVCR is the different boost levels per gear, but I don't know if those other controllers can do the same thing.
1 - 4 of 4 Posts
