depends what you wnat.. do you want performance, or you just want to have a dd ( dayly drive)
d15b7 is cheap abd rally good
d16z6 is better in performance
ok thanks i found a 92 ex with the z6 trans ecu everything to run will those mounts work in the 98 ex? i know to you this may sound stupid but like i said never had honda.
1995 Civic EX Coupe
it will bolt right up yes, but its best to keep your car obd2 also. so get a p2p ecu, obd2 disty and alternator and then you will be able to run it.
